Questions about Livernois tune
TIMOFNC
NORTH CAROLINA
Couple quick questions.
Is it true that running Stage 2 tune can actually improve gas mileage? If so, what is the general concensus on the real-life MPG gain? 10%, 20%??
Second, does having the tune affect the bumper to bumper warranty, or would the nice service people even know about the changes from the tune?
Thanks for the expert responses. Tim
darreli
Run'n from BPD
Michigan
I have the Stage 2 in my Flex and I can attest to better gas mileage. 1-2 mpg....so what is that 5%? I have about the same gains running the Stage 4 tune in the SHO. Haven't driven it enough to give you data on my current tune. The difference in performance along with maybe slightly better gas mileage makes it a "no brainer" for me.
As far as warranty goes.....well that's always the question. Ford has to show the tune is the cause of whatever your problem is. If a taillights goes bad the warranty won't be affected. If you blow an engine...that's another story. I feel pretty comfortable that LMS's Stage 2 tune is very safe.
D-Duff
MI
Off topic but have any updates come out from LMS for the sct tuner? I'm currently running the stage 3 which I received 6/10'. Wasn't aware a stage 4 was available.
D-Duff
MI
Any updates from LMS for the sct tuner? I'm currently running the stage 3 which I received 6/10'. Wasn't aware there was a stage 4!
mjhpadi
Pennsylvania
My mileage improvement is right in line with darreli's. I have been experiencing a 1-2 mpg increase since I installed the Airaid CAI with the Stage 2 tune.
TIMOFNC
NORTH CAROLINA
Is it correct that you have to use higher octane gas with the stages 3 and 4tunes? I believe i have seen people using 93 with the higher tunes, right?
LMSRick
Livernois
Westland, MI
We do have a stage 4. It has more boost, more timing, and no torque management. Our tuner Dan recommends higher octane with the stage 4, however I have several customers running it daily with 93 octane and no issues.
If you would like to try it, pm me with your name and email address and I can send it to you.
Thank you,
Rick
