lowc
aka vapah lock
nice job vortex! now get her running and take her out for a well deserved cruise
i feel your pain, when i did my swap every time i was right there i found something else. but on the bright side everytime you have to get back in there you cut the time in half
Excellent job Josh! Congrats on all the hard work paying off. Feels good, yes?
Great job Josh! glad to here all the good progress. makes you feel like you just climbed a mnt. dont it? id give it a good couple thousand miles before you do any "real" sho driving in it, just to let everything settle into place and let some of the new parts work them selfs in. Asfar as your issues with the rack i would def. try to get the rest of the old fluid out. althought it may just be an air bubble stuck in the rack itself.
valve train noise could be loose valve adjustment or chain tensioners that are not properly holding the chains tight. you should be able to determine which it is. what to do about it will be different depending on which problem it is.
Also, on the steering feel, I forget the exact VAPS connections. My 92 doesn't have it, and I never fiddled much with it on my 93. IIRC, there's separate pressure sensors and VAPS sensors, VAPS being on the rack, and pressure sensor being in the PS line. Perhaps someone can clear that up...
Keep in mind some of that "dead" steering feel may be due to the car needing an alignment.
*edit*
Forgot to add: I think you did a GREAT job, getting the swap done, buying the tools, and being patient with the project. You actually got it done pretty quickly! Nice work!
I just read through the whole job, and dang, very nice. I'm working on one, too, but it's a little different. What timing belt tensioner system did you use; the ATX or MTX? If you used the MTX how did you solve the extra pin that needs to go in the block for the MTX tensioner?
CK
you can change timing chain tensioners with the engine in the car - you just need to pull the valve covers, and then either take out one cam or take the cam sprockets off the cams to get the chain/tensioner stuff out/in.
