oil light randomly flickering
SuperHO
Mental Patient
St. Joe, MI
95 3.2 MTX. hopped in the car today to run some errands, and as i'm going down the road, the oil light starts flickering at me. it's not constant, it doesn't come on at idle, it's got oil and no hint of knock. it didn't come on for more than a second, and after maybe 2 minutes it didn't come back on. thoughts?
rbruso
unlikely
Tucson, AZ
It could be the oil pressure switch or the wire leading to it. Does the light flicker on more often on bumpy roads?
The sensor is available pretty much everywhere and is pretty cheap. It's a quick job to do during an oil change, but can be done anytime. You'll lose some oil, but it's pretty high up on the firewall side of the block and shouldn't be a lot.
While you're in there make sure the wire leading to it isn't frayed/melted/missing.
If you're still getting a flicker after you've checked the sensor and wires it might be time to thing rod bearings.
About $5 at Autozone:
SuperHO
Mental Patient
St. Joe, MI
rod bearings only have about 20k on em. i stopped for gas and checked the oil on a whim to find i was barely showing on the dipstick...not a huge issue since i use FL-1A filters which means around 7 quarts, but i just put a quart in the last time i filled up...so i'm losing oil somewhere, and it's not out the tailpipe or PCV. and after looking between typing sentences, i'm fairly certain my cam seal's lunch judging by the generous coat of oil on my rear motor mount and surrounding subframe. how hard are those to replace?
Phoenix
SHOHOLIC
QC , Canada
Its all here : http://www.shophoenixproject.com/lower60k/lower60k.htm
If you have done your rod bearings , I suspect you should be able to tackle this.
rbruso
unlikely
Tucson, AZ
If you're just doing the rear cam seal (the one with the sensor on it) you don't need to pull the whole front of the engine apart. It's a tight fit no matter what you do. Instructions for the rear seal are about halfway down page two of phoenix's link above (step 20).
The entire shophoenixproject.com site is great. Very good info throughout.
SuperHO
Mental Patient
St. Joe, MI
Marvelous...looks like I'm gonna be doing plug wires, plugs, VC gaskets and valve cover grommets while I'm at it. Time to give the SHO some love.
rbruso
unlikely
Tucson, AZ
None of those absolutely need to be done to change the rear most cam seal, though loosening the rear valve cover can help. People have changed that seal removing little more than the intake crossover tube.
Of course, if the leaking seal is on one of the intake cams that's another story.
SuperHO
Mental Patient
St. Joe, MI
fairly sure it's the one behind the cam sensor...it'd also explain the hard start condition and occasional miss under load at low rpm.
rbruso
unlikely
Tucson, AZ
That's the one that's leaking on mine. Just haven't set aside time to get it done yet. Not heavy enough to reach the ground or smoke on the cats but enough to totally soak the rear motor mount.
SuperHO
Mental Patient
St. Joe, MI
mine spit out 3 quarts of oil going to chicago last night...and why won't the fvcking seal from advance auto fit??
SuperHO
Mental Patient
St. Joe, MI
nope...it's the right one. i'm just gonna do it the hard way and yank the VC gasket and pull the cam cap. i don't feel like screwin something up.
Cocoa,Florida
IIRC cam seals are one of those things I have heard only to use Motorcraft.
Its only a couple extra bucks at the dealership.
SuperHO
Mental Patient
St. Joe, MI
unfortunately, it's also one of those things i can't afford to wait to do. the ford dealership here says 3 days to get the part, and i can't afford another 3 days worth of oil...
SuperHO
Mental Patient
St. Joe, MI
i don't care what anybody says...yanking the valve cover and poppin off the cam cap is far easier than the other way if the engine's in the car and you lack the hands of a 9 year old girl...
