Good advice, I'm good at finesse , hopefully I strip any. But what you did is a good alternative. the only thing i could find is a 5mm in a seven piece set. It has a rounded headed for angling the bit a little, Hopefully it'll still seat solid and hopefully the hex is 5mm and not 5.5mm because Lowes and Home Depot doesn't have a 5.5mm head on a 3/8" ratchet...
Worst comes to worse and I'll break out the heavy duty dremel blades and do what you did.
That sounds absolutely the same as my 93 that spit out a shim.
I first noticed something wrong when I would start the car and it sounded JUST LIKE THAT...but I would let it warm up and it would clear up and smooth out. What I was noticing is that's how it sounded when a valve was stuck open but this shim was still there in it's bucket. After several seconds, the valve would loosen up and all would be well.
My real problems started when the valve decided to pop closed while there was no cam lobe there to keep it in place.
It's definitely mechanical. Don't bother trying to troubleshoot anything electrical. You need to get that valve cover off and inspect every cam lobe, every bucket, every shim.
Really now? And how involved was it correcting the issue?
Thanks for the picture as well, now I'll have an idea of what's I'm looking for...
And I know it's without a doubt a the problem exists with one of cylinder #2's valves but I'll still look over the others.
Also, it's a little late to tell me not to bother with the electrical stuff
I've already ran through both the ignition and fuel system with a fine tooth comb. The low voltage at the injectors was a problem with out a doubt, I don't know if they had anything to do with the miss though. The short could have existed for a long time with no one knowing.
I do know that when I put a fresh set of injectors in the car would not start until I ran a fresh 12v wire bypassing the short.
If the wire was disconnected/no fire, as soon as I reconnected it, fired right up.
At least I can confidently say those systems are good as new now.
I will be taking the cover off tomorrow morning once the temps get high enough not to freeze my fingers. For eveyone following, expect pictures of the issue by afternoon.
On a side note, I will probably be needing at least a shim and hopefully nothing else, I know SHOSource sells them used but if anyone is feeling generous donations are welcome (;
