17x8 38mm offset
lowc
aka vapah lock
Quincy, massachusettes
no i know they are 18's but not sure if they are 7.5 or 8 i think its 7.5. dont know if this will help tell but the tire on the rim is about 9in wide
DJSHO91
Durham, NC
I've got 17x7.5", with 38mm offset, on my 91" and have had to trim and roll the rear fenders. Other than that, no other issues found. :salute:
image.php
SeanMc
NoMoSHO
DJ, those are NICE wheels!
I'm running a 17x8 with a 40mm offset, and a 245 tire, an unless I have a ton of stuff in the back, I have zero rub issues. I also have my rear camber at about -1.5 degrees. Tire wear is perfect.
Jh8990
New Jersey
oh ok i didn't know you had the 18" version
jedhead
westminster,ca
17X8 35mm offset OZ Superleggra with 235/45ZR17. I had to roll the rear fenders and still rubbed a bit in the front and rear when fully compressed. I also have koni/SS Linears. I think the 38mm offset may fit a little better.
Dsc00431
Dsc 0010
Bob
jedhead
westminster,ca
The OZ were the lightest 17X8 wheels that I could find at 16lbs each. I believe the TD come close.
Bob
