ahhh.... where to begin, never really had any problems with my v8 sho till now about 3 months ago went out side to dead car check for fuel pressure and did not have any. I'd been having low fuel pressure for a while so just thought the fuel pump was dead so i replace it still no dice but i did find out why i had low fuel pressure there was a hole in the fuel line in the tank.
After doing some checking around found the eec ign fuse blown so i replace it and it poped as soon as i turned the key. Everybody told me there was a short somewhere but after checking everything and getting no where i let the car sit for a month and a half one day i tried to start and it did.
it ran for 3 days on the 3rd day the fuse poped on first 30 seconds on startup.This time i notice that the check engine light stopped working when u have the ignition in the on postion and thought the light had went out but once the car would run it would work again.
After letting it sit for a long time i took the fuse panel apart looked fine put back together and it started this time it work for 4 days did the same thing in the morning as i was leaving out of drive way.
This time i took apart almost all the wiring in the car to find nothing ( that was a pain in the a#$) the only thing that looks weird is the ground wires for the pcm are not covered just there exposed but it looks like thats how it came from factory so i don't know.
This time once i put it back together i ran for a whole month even went on a 1000 mile trip then did the same thing in the morning while backing up. To make a long story short this is what i know fuse will pop with ccrm and pcm disconnected(fuel pump to) if i pull the first ign fuse in the engine compartment it wont blow and as of yesterday if i cycle the ignition a hole bunch of times the check engine light will come back on in the on postion and the car will run.
I replaced the ignition switch but it still does it. When i do this i have to hot wire the fuse or else it pop the fuse( i know i know) also when i hot wire it it has a big current draw when i turn the ignition on the lights go almost dead.
So has anyone ever had this problem before? Im at the point where i want to burn this car lol. Sorry for the long post and any help would be greatly appreciated.
