They said the struts would be sens a trac, which i know are 250 on shosource. and 400 would be total out the door for 2 front sens a tracs. I'll do this another day unfortunately since i don't have the $ for it yet.
As far as the shimmy in the front end, it has always felt off when cruising at high speeds, vibrating a lot, and almost always when i would floor it from a stop the car would pull to the side a lot! which im guessing wheel bearings cause this? I'm also pretty sure my steering rack has a problem too because there has always been quite a bit of play in the steering wheel. but the dealer wants about 500 for parts and labor and another 100 for power steering flush. ill save that for another day too i guess.
All in all, with getting the 1 control arm, 2 front hubs, axle (yes he did check the codes for the abs light, i specifically asked him to), new tires, and alignment, I figure the car should be driving much much better!
<snip>
