Steering Rack Replacement is Complete
itwonder
VA
The steering rack replacement job is complete, and wow what a difference. The steering feel is so much better now. It's clear the original rack had developed a slight binding that I had just gotten use to. It never leaked, but one symptom that pointed to a problem was the fluid would turn dark and smell bad pretty quickly after a fluid flush. The trigger to go ahead and swap the rack began with a wheel shimmy. True to form, a forum search revealed the most likely cause, inner tie rod ends. I took the front wheels off and held the brake disk and 9 and 3 o'clock to do a wiggle test. There was obvious play in the left side inner rod end; and it doesn't take much play here to cause a problem. One way to proceed was to just change out the inner rod ends. Parts prices for those vary from under $10 each for the lower end like Raybestos Service Grade up to around $26 each for Raybestos Pro Grade or Motorcraft. I'd also have needed to buy the Lisle inner Tie Rod Tool for around $55. Adding those dollars up made plan B seem like a better option...replace the whole rack. All of the remanufactured racks that I found come with new inner tie rod ends and boots. I went with a TRW remanufactured rack from Rock Auto. It's currently on Wholesaler closeout for $69.99, TRW PN 15780R, and it requires no core charge. That's great because core return shipping something like that would otherwise eat up any savings from dealing with Rockauto. This is a deal imho.
The rack looked great when received, and it is an exact match with the Ford PN cast into my original rack. I suppose this is a SLO rack, the description says "exc SHO", but you can ignore that. I did not bother checking for the little turn limit bumpers that are installed on the original SHO racks, but said to be missing from the SLO racks. I have not noticed any wheel well rubbing.
The FSM procedure was right on for the removal and installation. Despite some posts here to the contrary, the FSM is correct and there is no need to lower the subframe to swap the rack, at least on the MTX. It does take some manipulation. You have to push the input shaft piece up into vehicle to lift the mounting bolts out of the holes. then you need to lower and rotate the rack so the input shaft will pass between brake booster and the floorpan. Then you wiggle it out of the LH fender apron opening. The messy part of the job was flushing out the lines, which is important. I changed the rubber hose on the return line, reusing the factory metal end piece. There is a double ridge formed into the line that secures the factory crimp; be careful not to mess that up when cutting off the old crimp. It's difficult, but I pushed the rubber line up onto that double ridge enough so I could get a clamp there. there is nothing else to hold the rubber hose onto the metal tubing, except friction. I added a second clamp on the smooth part. The pressure line was new from when I replaced the PS pump, so only a new teflon seal was needed. New teflon seals come with the rack. They need to be stretched out to fit per the instructions, a pain. You'll see from my earlier post there is a little flow regulator in the pressure side of the original rack that is not included with the new rack. Area91 said he moves them over, so I followed his lead and did the same. The mounting bolts also need to be moved over. They are splined into the casting, so don't try to turn them out. I pressed them out with my vise, but I suppose a hammer would work too. Grease them well before inserting into the new rack to prevent steel to aluminum corrosion.
The heat shield needed some repair. Aluminum tape fixed it up like new. I used plastic license plate bolts to reattach it to the subframe instead of those PITA push pins. The new rack slides in pretty much the same way the old one slides out. You might want to tape the ends of the bolts if your subframe is nicely painted and you don't want it scratched up. Inside the car, one thing I noticed when removing the old rack was the upper intermediate shaft bolt was torqued to the lower end of the spec., and it seemed like there was some play there. When I put it back, I did something I rarely do. I actually torqued it 5 lb-ft over the spec.; it's a big bolt and it can take it. No play there now.
One mod I did was to add a 3/8" Magnefine filter in the PS return line to catch any crap that might otherwise circulate. I located it just above the PS cooler; there is plenty of open space for it. I refilled the system with the specified Type F ATX fluid, I selected Castrol. Since I had counted the turns when removing the outer tie rod ends, it was easy to get them back on the same as they were. Alignment felt pretty good on the test drive, but of course I'll have it checked. All in all, a very worthwhile project.
Westerly, RI
Thanks for the writeup! I was eyeballing that TRW rack, as I need to replace mine this winter, but was a little iffy because it said "except SHO". I feel better now, knowing that someone has installed one and it's fine.
Racer X
SHO Pilot, Retired
Connecticut
It says exc SHO... is the turns ratio the same as the SHO? IIRC, the SHO rack has a lower ratio than the SLO rack.
zak
east of Hartford
Gen 1/2 SLO 2.52:1
Gen 1/2 SHO 2.52:1
Gen III SHO 2.7:1
Rack ratio data i've collected over the years.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Umm... beat you to it?
My rack thread
nice write up tho.. :)
10k miles and I havent had an issue with mine yet either.
I found it on ebay under that pn, got mine really cheap.
itwonder
VA
The rack ratio is the same as before, so no worries there.
One other thing to add, an 18mm stubby open end wrench is handy for the pressure and return line fittings. You can get by without it, but tightening them is a lot quicker with a stubby.
itwonder
VA
My rack thread
Great minds think alike :)
But after a bad Fleabay experience where the seller didn't want to stand behind a factory defective Y pipe, I steer away from that mess and stick with Rockauto.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Oh yea, I don't know if I could get that deal again, I think it was a one time thing where some guy had a few extra. He only had the pn too, couldn't tell me what they were for, so I took a chance. :)
Did you by chance swap those 'travel limiters' in there? I was pretty suprised to find out how much little travel they restrict. Things were only 1/8"-1/4" thick. But the rack has been holding up fine... I cant say I've noticed the different ratio at all either.
itwonder
VA
No, I didn't bother with those little turn limiters. I have not noticed any rubbing; probably dependent on what tire the car has to some degree.
Radical540
Michigan
Good write up.
I'm suspecting that mine will need to be changed soon (though I only have 61k on the car). The P/S pump is making the proverbial "whine" before it buys the farm! But I'm trying the suggested "Lucas Power Steering" fluid to see if that will address the whine somewhat.
Anyone ever changed the P/S pump? What's involved??
itwonder
VA
Good write up.
See http://www.shoforum.com/showthread.php?t=112836. But I would not change the pump just because it is whining. A lot of them whine to one degree or another.
Radical540
Michigan
One fella I talked to said the best thing to do would be completely flush the P/S system. He said this is (somewhat) easily accomplished by disconnecting the P/S lines at the cooler (Where is the cooler?) and then starting the engine. In doing so, one line will "pump out" fluid (into a container), while the other line is allowed to "suck in" fluid (from a separate container).
Seems easy enough............
Basically, you're using the P/S pump to act as it's own siphon pump and "fill" pump.
itwonder
VA
The PS cooler is under the car on the left side, just behind the radiator and right next to the horn. But imho there is a better place to disconnect the line. Pull the return line (smaller of the two) off at the PS reservoir. Now, when you do that, you're going to need to have a small container right there under the ****** because the reservoir is going to drain. Once it is empty, put a scrap piece of PS hose on there with the free end either blocked off or tied well up above the reservoir. For the return hose, get a 3/8" double barb fitting (plastic is fine) and a length of 3/8" clear plastic hose long enough to reach a bucket. Both are hardware store items. Tie the hose to the bucket so it won't pop out during the flush. To do the flush, you need a helper. He will start the car and turn the wheels back and forth from stop to stop. You will be pouring ATF into the reservoir as quickly as you can to keep up with the pump, which will be emptying fluid into the bucket. Once the fluid going into the bucket is running clear, you are done. It should take about 1 gallon of ATF to do the flush. Reconnect the lines and top off the reservoir to the proper level. Ford specifies type F ATF for the SHO PS system.
Radical540
Michigan
...that's a great write-up!! Unfortunately, I'm a visual kind of person, so I'm still trying to visualize what you wrote in my mind. LOL. But I think I gather what you're saying. So basically, the contents of the return line, are being dumped into a bucket (?), since it's no longer connected to the reservoir. Do I have that right?
itwonder
VA
Exactly. In through the reservoir, and out the extended return line into the bucket.
Schiv1010
