when rotating cams for welding...
Liquid_force
Lawrence, KS
Can you use the nut on the front camshaft instead of the starter?
It seems a lot more practical when you're only going 90-120 degrees.
Another question - when disconnecting the injector connectors I think every single one of the retaining clips broke. I suppose it would be very strongly recommended to replace these. Cheapest place for decent quality connectors?
LJRuddy
Pop lock n drop
Poaceae fields
I'd just put a socket on the crank bolt and rotate the engine that way.
BTW... What part of larry town you live in? I was born and raised in Overland Park. :wave:
trainguy1989
SHOtarted
Wichita, Ks
My sister lives in Lawrence, Ks. And I am in KC. Let me know if you need help.
Liquid_force
Lawrence, KS
Just north of 6th St. and a few blocks west of Iowa.
Thanks, going ok so far, although the longer it sits the harder reassembly is going to be.
