V8 SHO parts
I pulled out the rear brake line. These are Ford parts and only a year old. Shipping would be expensive.
Got the rear proportioning valve out with the bias plugs.
Gas tank filler pipe.
Rear hubs with ABS sensors.
26 mm bar. SOLD
Somebody got the good one. The TR one I have has the bubbles.
Got a good RM one. :)
Here's more NEW parts from the bin
Upper radiator hose
Accessory belt SOLD
Water pump belt N/A
TRS SOLD
Crank sensor SOLD
Cam sensor
TP sensor
Pre Cat O2 sensor
LR DISC brake hose SOLD
RR DISC brake hose SOLD
LR DRUM brake hose
RR DRUM brake hose
Rod bearings SOLD
Rod bolts SOLD
Autolite Iridium 103 (8) -1 range colder
Autolite Iridium 104 (8) - stock range
tardboy21
Woodbridge, NJ
The belts new I assume? PM me a price/shipping on the Accessory and Water Pump belts, Rod bearings, and 98 engine wiring harness. Got any new piston rings too?
Yes it is, if the car has one. Somewhere along the line Ford quit putting then on the SLOs.
Do you still have the V8 Engine Tool Kits? If so, how much did you want for them and are they fully complete?
I have two. One is complete, manual and all. One is missing the tappet holder.
T96P-1000-FH/FLMH
If you are looking for the valve shim removal tools you need the shim compressor from the V6 SHO tool kit, along with the tappet holder. But I have one of those too:)
Both tool kits SOLD
What exactly are you looking for?
welcome2daSHO
Crowderhead
Milwaukee, WI
do you have an ashtray and non star wars cupholder? (the two plastic parts that surround the shifter) and rear marker lights with the sockets for bulbs? how much to 53228 thanks!
danmn1313
SHOgazm
You wouldn't happen to have an ashtray and the rear tail lights? If so can I get a shipping quote for both items to 60550
