very disappointing night at the drags!!
sperold
Last to Know
If you pulled a 15.5 quarter and drove home afterwords, you had a pretty good night.
What you are forgetting is a lot of the 1960s / 1970s muscle cars did not turn better times than yours. And that is with over 400 cubic inches (yours is 183) and gobs of torque.
RonPorter
SHO Club of America
Lake Orion, MI
Yes that was the '96 MTX, not sure what else is done to it. I want to see his 60' times and trap speeds too.
My best run was 15.337 e/t, 2.450 60', 93.75 mph. The car has a SHO Source equal-length catted y-pipe, a SHO Shop in-fender CAI, and I just put in Konis/SS Linears and ALSFB (still need to do front strut rod bushings) and a Southbend Stage 2 with a stock flywheel (which replaced a Spec disc and Fidanza fw).
:moon:
There was another V running. Not a new one though.
With that trap speed, you are about a half-second above what it could do.
jmpSHO2nd
Massachusetts
I know but I am still disappointed, I thought these cars ran 15.5 stock and not that I have crazy mods but I have some and I honestly thought it would be in the low 15s or just maybe 14.9, that was my goal. I wish I could say that I had traction issues but I didn't.
somedude_001
Western NY
maybe if you tried to trick the car into thinking it had a turbo by making turbo noises while going down the track it would help. That is what I use to do and it worked.
sperold
Last to Know
Pick a day where you have cooler temperatures (50s or 60s) and you will reach your goal without any further modifications.
Not having traction problems is a very good thing.
If you could lower your tire diameter, you might benefit by using a little more rpm through the traps, but you might develop traction problems too.
somedude_001
Western NY
the ATX sho does not have traction problems unless you run a garbage tire. **** I ran 205/65/15's on my turbo ATX and I am confident I would have ran 12's like that.
