Shifter problems
94$ho
Pa
My 94 sho shifter button locks when I start the car and won't go out of park. Any ideas on what It is or how to fix it?
hawkeye18
Sorta cares
Norfolk, VA
This is correct. The BOO (Brake On/Off) switch controls the shifter interlock to ensure you are stepping on the brake before you shift out of park.
The easiest way to tell whether the switch is broken or not is to simply see if the brake lights light up. Put something heavy on the pedal (a brick, etc.) if you don't have a helper handy. If they don't come on - and they should come on regardless of key position, whether the keys are inserted or not - then the switch is broken. It's about a $30 part at advance auto parts. It is located on the brake pedal arm above the part you step on.
If you put the key to position I, which is between OFF (0) and ON (II), you will be able to shift regardless of the brake pedal switch. That is the backup, so you can push/move/drive it in an emergency situation.
94$ho
Pa
I put a new brake light switch in and that didn't fix it. Any other ideas on what it might be?
94$ho
Pa
No the switch didn't do anything just made under the dash a lil shinier
hawkeye18
Sorta cares
Norfolk, VA
well if the brake lights still don't work, then either the fuse for it is burnt out, or the wiring is bad. If it was the fuse, and you replace it and it's fine, then it was probably the switch that caused it to blow, so consider that for a moment.t
94$ho
Pa
The fuse was blown and I replaced it. Shifts just fine now thanks for the help really appreciate it.
hawkeye18
Sorta cares
Norfolk, VA
Good to hear! Yeah, the switch often likes to short out internally, and will blow the fuse for that circuit in a second. Good thing you replaced the switch before you went through like six fuses, eh? :rofl:
94$ho
Pa
Yea fuses can get to be a pain in the ass. :thankyou:
