Anyone have issues with buying belts for the MTX?
LJRuddy
Pop lock n drop
Poaceae fields
I finally got my 95 running today after it sat since november... Went to buy a new alt/AC belt as mine was broken. They sold me a 44.5" belt and when I went to put it on, it was about 2 inches short even after I completely took off the tensioner pulley. Went back and bought a 46 3/8" belt and it works fine. I could have gotten away with a 45.75" as I bottomed the tensioner out completely and its still a tiny bit lose.
So whats the deal with auto parts stores? Did something change in their computers? What size are you all running?
K-Dawg
Treasure Coast, FL
No. I'm surprised this isn't a more widely known issue on the forum. Almost all the stores list the incorrect size belt for the 94/95 alt/AC belt. The 89-93 MTX use a 44.5" belt and the 94-95 MTX use a 45.5" belt. I think my numbers are right.
LJRuddy
Pop lock n drop
Poaceae fields
I'll be sure to write that length down and shove it in my center console with all my other SHO notes. Now I know the correct length. Thanks. :salute:
lowc
aka vapah lock
Quincy, massachusettes
ive never had a problem with ordering belts for my 92 and i use a local parts store every day
you never know thought it may have been packed wrong
ran into the same issue with my pass side lca today....right # wrong part
KyngofPop
Freday-day
Charlotte NC
Had this comPLETE issue about 4 weeks ago and I kept the belt container and the only bent that fit from Auto Zone was the 455K6. They listed the 450K6 i think and after nearly a days worth of trying other part stores the 455K6 worked sorta fine. I STILL get the alternator light at high RPM's and the alternator is a KNOWN good unit but there's no squealing anymore so I'm good for now. I even chanced my tensioner due to this mess smh!
CademiaX
What's an SHO?
Utah
I had the same issue, they game me one that was too short at autozone.
wingtip80
delaware
Probably a ***** at the auto parts store.........
I was getting plugs for my old ford with a 351-m (modified). And the kid asked me if I modified it my self. It came up in the computer 351 modified. And he thought I did it:laugh_ti: I guess I put the change in the computer too.
jonheese
Used-To-Know-It-All
Fogelsville, PA
See, this is the third time I've heard someone say this, but I upgraded my '90 to the '94/'95 3G alternator setup, and used the belt from the original '90 setup with no issues. The alternator was definitely the '94/'95 unit (had to do all the fun bracket swapping and head cutting), and it came with the pulley pre-installed.
Shouldn't my '90 belt have been 1 inch too short?
zblackbeast
SHOtarded
Omaha, NE
Yeah.. remember when my battery exploded? Reason being was the PO put the wrong size belt on and a smaller battery.. wheni bought a new battery, i bought the correct size and the tensioner rubbed a hole in the bottom of the battery! All MTX's need 1 size bigger.
LJRuddy
Pop lock n drop
Poaceae fields
And the plot thickens... This is weird. Could it be the tensioner pulley? What about the AC pulley? Maybe one of those are a different size or located differently on the engine? If I remember correctly, the compressor is mounted to the same bracket that the Alt is, right? Maybe that bracket is different between generations?
K-Dawg
Treasure Coast, FL
http://www.shoforum.com/showthread.php?t=35104
http://www.shoforum.com/showthread.php?t=52674
http://www.shoforum.com/showthread.php?t=71541
http://www.shoforum.com/showthread.php?t=88363
http://www.shoforum.com/showthread.php?t=9989
I know that a 44.5" belt would not fit my 95 MTX. Maybe your used 44.5" belt was stretched just enough to work?
jonheese
Used-To-Know-It-All
Fogelsville, PA
Could be, but I'm fairly sure the part number for the entire tensioner assembly is the same for all MTX SHOs.
Again, same part number for the A/C compressor, and I believe the pulley is normally included. I'm not aware of any differences in this between generations.
Yes, the motor mount bracket (which also functions as the mounting bracket for the A/C compressor and the alternator) and the compressor-to-alternator bracket are both definitely different between the '94/'95 MTX setup and the '89-'93 MTX setup. This is the biggest part of the upgrade procedure, and I have the '94/'95 brackets (necessary just to physically bolt up the 3G alternator).
That is definitely possible, although that'd be one **** of a stretching. I didn't notice how far I had to move the adjustment on the idler, but I was putting it all back together at the time, and I had no idea the belts were any different across the generations, so I really wasn't paying much attention at the time. I suppose I ought to go out remove my belt and measure it... Maybe later. :)
DavesNOThereMAN
NJ
Thats funny cause I bought BELT 445K6 from Autozone the other day and its like an inch shorter and no way will it fit on my 94 MTX..
KyngofPop
Freday-day
Charlotte NC
Dude that is NOT the correct belt at ALL! I have the box for the correct one from Auto Zone here and it is the 455K6/6PK1155. That 445K6 had me changing parts that were not necessary and turned a simple belt change into an all day affair.
crystizel
