MLP mod for ATX to MTX
the4biddendonut
Hurry up meow.
Elk River MN
I've been toying with the idea of turning my 93 ATX into an MTX by parting out my 91. I have one question at this point that I'm not quite so sure about.
Do you really need to modify the MLP and just leave it hang in your engine compartment when you do the ATX to MTX modification? Or could you just leave the MLP out and make your connections at the harness??? Has anyone done this? Does anyone have pinouts for it?
Here's what I'm talking about.
4645244350 8e47007ac5 o
Phoenix
SHOHOLIC
QC , Canada
I ditched it.
Its there to show you how it works , theres no point of leaving that there if your wires are correctly connected.
lowc
aka vapah lock
Quincy, massachusettes
im in the middle of same swap and i am useing the 3.0 harness and ecu
just a heads up if you use the right up that Phoenix is hosting witch from the pic it looks like you are it does not say but you need to swap out the rear exhaust manifold the 3.2 one hits the top of the rack making it imposible to install rest of exhaust
Shoaz
Studly dood
Scottsdale, AZ
You can try just leaving the MLP disconnected, but this doesn't always work. You can also just do a little rewiring to have the same effect, which is what i wound up doing on the Pumpkin after the MLP popped solder joints a couple of times.
To bypass the MLP connect the two wires to enable the starter and wire a resistor into the transmission circuit. As seen below connect the wires to pins 5 and 8, and then wire a 400-ohm resister between pins two and three.
If you want backup lamps, wire the backup switch through pins 6 and 7.
You can also wire the clutch interlock switch through pins 5 and 8 if you want to keep that function.
MLP 100 sm
the4biddendonut
Hurry up meow.
Elk River MN
That's what I was afraid of, solder joints breaking.
Perfect. Just the info I was looking for. Thanks a lot everyone.
SuperHO
Mental Patient
St. Joe, MI
stupid question time that nobody else has the balls to ask...what the frick is an MLP?
Shoaz
Studly dood
Scottsdale, AZ
Manual Lever Position sensor. It tells the computer which of PRNDL is selected in an ATX. For an ATX->MTX conversion it usually needs attention.
