My spider gears blew up!!! Oh no!
91 SHO Black
OH FO SHO
Vancouver WA.
i was cruising at 85 in fifth car **** shifter popped out of gear and smoke behind me. pulled over and my fluid was dumping out. all the gears still work, **** the car will still go.(i didn't drive it) this has happened to me once before and i had no choice but to give the repair to a shity shop that did everything wrong ( i was 200 miles from home) so i surmise that my spider gears through a chunk punching a hole in the case and now i'm pretty F'ED. There’s a sho of the same year in a junk yard and i'm wondering if this is so common that it would be unwise to use a unknown used sho trans. any incites? from any one please. p.s. also does anyone know were i can find procedures for the swap.
Racer X
SHO Pilot, Retired
Connecticut
Yes, it's common. Do a search for SHO Boom.
Before you install the new transmission, you'd do well to have your differential welded at the very least to avoid a repeat performance.
And stop doing burnouts if that's your thing.
LOUDSHO92
Rancho Cucamonga, CA
are you talking about welding the diff pin?
Yes or get a Wavetrac. You blue your differential pin. Welding helps but the best way is to replace.
You might want to contact us at SHO SOurce. We can get you a used transmission and help with the install.
SuperHO
Mental Patient
St. Joe, MI
it becomes routine after your 4th or 5th one. simply put, stop doing burnouts.
SuperHO
Mental Patient
St. Joe, MI
more reliable, maybe...but not stronger. personally, next time i eat a trans, i'm gonna have the diff yanked and have a thin steel band wrapped around it to hold the pins in place until i can get a wavetrac or a quaife built tranny.
moobypets
mooby
quebec
yeah this i im sure off but before i find 1000 in my pocket it will be long lollllll
AREA 91
Area 91
** we can weld our diff so it will make it stronger
where can i find the info
Send me a P.M. I offer this service.
Sorry Matt, couldn't resist!:laugh_ti:
If you are on your 4th or 5th MTX tranny, you need to be kicked in the sack!!!:hyper::fit::confused::eek::shrug::braincramp::theyareontome::ohreally::shakehead:cuss::3gears:
:neverlearn:
The Wave Trac and Quaife are worth every penny! I cannot stress this enough. What good is having power that just goes up in smoke? If you start to add up the cost to replace a blown tranny, the Quaife/Wave Trac becomes very affortable quickly.
Used MTX tranny $350.00
New clutch,pp,tob and resurfaced flywheel $350
Labor rate to R&R tranny and clutch $500
$1200.00 just that quick to get you back on the road with no improvement in performance or durability.
moobypets
mooby
quebec
yeah and a wavetrack is 1000 plus shipping
plus all the rest that goes with it
+ labor and all about 1700
moobypets
mooby
quebec
euuu i was maybe getting the wrong number it was out off the blue
1395 sorry i was wrongggg
