found sho
shospeed
austin tx
I bet they would take $500 for it.......
And you can go wrong with that!
bottonic
Sho ******
East Troy, WI
"needs a new head" in other words, needs a motor. Can anyone say CAM FAILURE! Unless you have a spare V8 laying aroung, I would steer clear of the car. IMHO. Anyone else care to chime in?
trevhelton
Yakima, Washington
just called the guy he said he would go as low as 600. All the parts are there ust missing the heads from the front set. Any knows what is involved as to putting it together. It is a 3.4 engine. How much am I looking at to get a set of heads for the front. The guy said the cams are fine it was in the process of having some work done to it and the owner took the heads in to have them machined and never paided to get them so it has been just sitting.
trevhelton
Yakima, Washington
Not trying to sell at all looking into buying one of these dying breeds. But dont want to get jimp in th process. If I posted in the wrong place I am sorry. But I thought this is the general forum and the link was attached so anyone trying to help me could see the add and make sure what I am saying is correct. Never touched a v8 sho.
llamaking122
Green Machine
Columbus, Ohio
He posted the ad to get opinions on purchasing the car, not trying to sell a car or advertise for a buddy of his. I know it's "forum illegal" to post CL ads, but I think exceptions can be made. :swing:
well i know what your saying, and im not trying to be a ****, but alot of times they will delete it. but who knows. he was new(well not high post count) so i was just letting him know. just thought i would help ppl out so the thread doesnt get deleted. but if i had time i would buy a cam failure v-8 but i dont have a garage or time sooo.....
trevhelton
Yakima, Washington
How would I know when I go and look at it if it is a cam failure and if it has been repaired. From what I understand all I need is the heads which may be still around the shop that machined them will call on monday. They will have been laying around for like 2 or 3 years now so probally not still there.
llamaking122
Green Machine
Columbus, Ohio
well look at the top of the pistons also. see if they hit the pistons they most likely did. but who knows.
NebraskaSHO
Harumph!
Omaha
Not worth the head ache. Find a running car and have it welded. Especially if it has been sitting for 2 years. You now have possible brake issues, flat tires, possible bearing damage from when the valves and pistons hit, who knows.
shospeed
austin tx
Ohhh no its not just any ford v8. Its a SHO ....
To check for cam failure well.. If the cams are split or cracked in 2 buy were the cain goes.
Its preaty cut and dry.
IM Buddy8
Rhode Island
Will do are heads hard to find for these or just any v8 ford heads will work
Yeah just take ANY year mustang heads they will work perfectly! No that's mean they won't don't listen to me but I would not buy this car it needs a WHOLE new motor. The one there is not worth messing around with.. Also who knows how that tranny will be not being driven and everything else like someone else stated. Pass it on and buy a running one and weld it!:swing:
Westerly, RI
The heads are V8 SHO specific, and honestly you've been given good advice. You're going to spend about $2k for rebuilt heads, and another $1k or so for head gaskets and head bolts (hard to find), on an unknown engine that could have other problems once you get it fired up.
If you've got a V8 engine, or a crashed up parts car with a good drivetrain, it's worth it. If you don't have that stuff, pass on the car.
NebraskaSHO
Harumph!
Omaha
If you are handy, it is not going to be too tough, except for finding all the parts that are needed to put it back together. Someone may have came by and pulled a few parts in the time it sat too.
If the car has sat (again I said this in post #11) you can expect other problems to quickly come up after you would get it going. Was the engine at idle when it failed, WOT, Half throttle, Cruising, Decelerating, etc. etc.
Not worth the trouble IMHO unless you have a wrecked parts car to swap everything into.
Again, just my .02
:deadhorse:
shobroooo
