Who's know's anything about Probes?
SHOstuff
Houston,TX.
I have a Probe that I'm working on and it's not starting. I put a electrical tester in the injectors and there's no current passing thru it. Anybody know's what it could be that could keep it from having current thru it? A module maybe?
Rubix
Try posting this in the general chit chat and/or the capsho forum rather than here, you'll get some hits :thumb:
jmpSHO
Massachusetts
Did you check all the injectors for power? If none are getting power it might be a bad computer.
SHOstuff
Houston,TX.
How on earth did this end up in the Gen 4 SHO section??
LMAO...I'm sorry fellas but all I saw was general discussion and didn't pay GEN 4 nxt to it no mind. I was just trying to get an answer to my probe problems cuase I want to get it going so badly.
warmonger
earth
i've had 13 gt's and 5 mx6 ls'. i'm willing to bet its the disty ignitor..very very common on 93-95 and less common on the 96-97,does still happen. you can either use a gm hei and bypass the stock ignitor if its a 93-94 or replace the whole disty. if you get a jy one becareful,theres 93-94 specific,95 specific and 96-97 specific.
also check the fuel pump cut out switch in the trunk,bad crank sensor,or oil in connections. good luck,really fun cars with a sexy exhaust note when modded properly
