How do you replace valve stem seals?
boat
Likes blue ones
Tallahassee, FL
I have a set of low milage 3.0 heads to put on my 3.2 MTX. They have been sitting around for the last 10 years not on an engine but stored in a basement with valve covers on them.
I want to change the valve stems seals but have had trouble finding anything here on the forum on how to change them.
Is there a procedure?
If so, what is it? If not, explain then how to do it.
What tools do I need to do the job?
It's on the shophoenix site. With the heads off the car it's a cakewalk as long as you have the rotunda tool kit.
Phoenix
SHOHOLIC
QC , Canada
Amen to that , you absolutely need the rotunda kit at least to remove the valve springs. Ive tried some other cheap ebay stuff in the past , and its a PITA.
If the heads are on the car , you will need an adaptor to put compressed air in the cylinder through the spark plug hole so that the valves dont fall in the cylinder.
If you have a spare shortblock , temp bolt the heads on it while doing the springs , it helps alot when you put the pressure on the springs with the tools.
To remove the seals , you can do it with pliers if your careful , to install , theres also a tool in the rotunda kit to do it right.
boat
Likes blue ones
Tallahassee, FL
Thanks guys.
The heads are still in the boxes I got them in. And I can come up with a spare block to mount them to. Would it help if that block was mounted to an engine stand?
Would it be wise to try to borrow a 3.0 Rotunda kit from someone? Or should I go to flea-bay and pick one up for my own uses?
Phoenix
SHOHOLIC
QC , Canada
Yes , if the block is on an engine stand , its even better.
For the rotunda kit , it rarely comes under 150$ , I think theres one at 250$ right now. If you think its the last time you will do those kind of jobs , rent it. If you plan on playing with SHOs for quite a long time , buy it. It's almost like an investment , you can always sell it later on. These kit are kinda rare , I doupt the price on the things will drop anytime soon.
SHOtimer
#2910
Santa Clarita, Ca
One click of the search button and it is amazing what you will find....
http://www.shoforum.com/showthread.php?t=26427&highlight=valve+stem+seals
...I was also going to link you to shophoenix, but that is already in the thread.
When I built my motor I had the machine shop replace the valve stem seals and pressure test the heads along with making sure they were cleaned up and properly surfaced.
It was a couple hundred if I remember correctly...but my motor now has 80k on it....doesn't leak or burn a drop of oil.
Doug
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Doug
That's the route I went, and the route I sugguested to him too. ;) I don't think it's the "right job" for him. The place here in town charged me $300, including the valve grind. :)
Phoenix
SHOHOLIC
QC , Canada
I got quoted for 400$ for a resurface and a 3 angle valve job at the performance shop over here.
