Fuel pump and filter???
SHOred
North Carolina
What brand fuel pump and filter are the preferred for the GenII MTX?
Is anything more than original specs needed to a stock engine?
Thanks,
Henry
joesho_gb
95 ATX
WI
If you're running stock injectors, then the stock pump and filter are all you'll need
sdpatt
Sr. SHO Engr.
Dallas, TX
He's right, but the additional flow of the 155 lph Walbro will provide extra margin for a longer time.
SHOred
North Carolina
Is there a certain brand pump that is recomended? Should I replace the whole unit that goes in the tank? (sending unit, pump and strainer) Allso, how do you remove the hoses going to the pump without breaking the coupler?
Thanks,
Henry
SHOred
North Carolina
Thanks guys. I think I will go with the Walbro and set my mind to rest. I don't ever want to pull the tank down again.
Thanks,
Henry
