How do I get the last bolt off the alternator?
Ashley_MTX
North Carolina
Okay all- finally got a (very windy) day to change the alternator. I have the belt off and all but ONE bolt off. It sits under the bracket on the intake and I've got NO room to maneuver. It's a 15 mm bolt and there's stuff in the way so I can't get an extension in there to get some leverage. I hit the engine on one side and well...some hard lines and the front of the car on the other.
Attaching a picture- I need any advice on tools or tricks you all have. I'm hoping to get this taken care of today but I AM going out of town soon so it's not an emergency yet but...it will be fairly quickly.
Thanks again- Ashley
December
Rubix
I guess you're just using sockets? A rachet wrench might be helpful here.
Can you get a socket on there with a little range of motion or none whatsoever?
Ashley_MTX
North Carolina
I have ratchet wrenches...problem is where the alternator was connected...I guess it was a ground wire you can see in the picture it looks like it's to the left of the bolt- actually it's ABOVE the bolt. can't get a ratchet wrench in there because it hits that.
kikkinasphalt
Wrrrrrrrr
Missouri
i used a couple long extensions and a swivel-socket
Rubix
Ahh yea I see that. Does a socket wrench with a socket on there clear that ground bolt? Probably hits that hard line though doesn't it.
Ashley_MTX
North Carolina
Yep- that's the problem. I got some offset ratchet wrenches. About to go test to see if they clear.
milestoldyouso2
new york/maine
What about just a regular open end closed end wrench? The closed ends are usually angled so you should be able to clear it. If you need leverage then slip a peice of pipe over the wrench, just be careful not to over do it.
Ashley_MTX
North Carolina
Offset ratcheting wrenches worked. Now I can't get the damn thing out of the car. Just the 3 bolts right? Two on the left, one on the right?
Ashley
Rubix
Hammer time... don't get too rough though.
Ashley_MTX
North Carolina
Hm I guess my post that I got it didn't get up here. Ran out of daylight and knocked the washer on the tensionor down off the engine bay. Little bit of an oh shit moment but hopefully with some more light I can find it tomorrow. Thanks all!
shocrates
will never know
NJ
FWIW, that post above the bolt you were having a difficult time with is not for grounding. Don't forget to connect the wire to that stud before you connect the battery.
Ashley_MTX
North Carolina
Hey thanks- my car has a lot of random plugs that go to weird places...or not to anything so...sometimes I just make things up.
Anyway it WORKS. Found the part, got it taken care of, started the car- no battery light anymore. Guess I fixed it. I'm taking the battery to be put on a charger hopefully tomorrow so that it's not so dead anymore. Next stop- finally doing that multifunction switch.
Thanks again everyone.
Ashley_MTX
North Carolina
Psh whatever as he's said he doesn't work on his own cars. I do. And my SHO bit me a few times. But yeah- Sam shipped out on the 28th, the battery light came on Dec. 2, I got the alternator yesterday- and today it's fixed.
If he were here it would have been fixed by the 4th...this I know. But yeah he's there. Thread is called D'oh in gen. chit chat.
hawkeye18
Sorta cares
Norfolk, VA
Yeah the post on the alternator is the B+ terminal... I have arc welded wrenches on that thing by not putting it on before the battery terminals.
Also, there's a joke in that first line somewhere... I'll let james find it, though. :evilgrin:
