turbomanny
Blue Gen II w/ Gray leather - 139,000 miles - new tires - 5 speed MTX w/ Quaife Differential - ShoShop Y-pipe - Dynomax cat-back - ShoShop Underdrive pulleys - Spec Stage 2 Clutch w/ aluminum flywheel - 1996 Brake upgrade - Police package, lower control arms w/ HD ball joints - Delrin strut rod bushings - ShoShop subframe connectors - rear strut tower brace. ***Lots of extra parts, including: 3.2L engine - 3.0L short block - 5 speed MTX - 2 Nitto Drag radials on slicers - 2 cylinder heads - ShoShop Aluminum flywheel - rod shifter...just to name a few!
$2500.00
I've had a lot of questions about rust -- there are the 2 spots you can see in the pics -- one on the driver side back door, and the other on the passenger side by the gas tank. There is a little spot on the rear trunk lid and a little on the inside seams of the 2 front doors - but they are not rusted through.
The car starts right up - and runs good -- the trans makes a bit of noise at idle - she shifts good and all gears do work. May be the bearings or the gears?
Please PM if interested...
Thanks,
Yeprem
$2500.00
Thanks,
Yeprem
