Snapped a wheel bolt
davidkristinab
Missouri
hub bolt, whatever you call it. Can i buy just the bolts or are they pressed in? I found the assembly at autozone for about 60 but just seeing if that was a must. Thank you
sperold
Last to Know
You have to pound out the old one with a 5 lb hammer. The new stud has splines on the sides and you have to draw it up into its final resting place with the nut and a pile of washers or some equivalent. Just get the correct stud in the beginning, that is really the hard part.
ShadetreeSHOguy
Postwhore
Dallas, Ga
This could be worse than that time I caught stupid. It's a ************ to get rid of.
i guess you'r still fighting it? :angelnot:
as far as relating to the problem, you can just pull the new wheel stud through the back, put the brake rotor on, put a lugnut on the new wheel stud. Tighten the @#$(& out of it. Pop the wheel nut off , pop the wheel on. Good as new! :thumb:
Westerly, RI
Fighting what? :)
davidkristinab
Missouri
does anyone know exactly where and wich one/size to get? part # possibly? Thank fo the info though. Whoever had the car before me really fuggered it up. More issues to come probally
