davidkristinab
hub bolt, whatever you call it. Can i buy just the bolts or are they pressed in? I found the assembly at autozone for about 60 but just seeing if that was a must. Thank you
:swingamn, Crank Cancer is eating up wheel studs now!!
This could be worse than that time I caught stupid. It's a ************ to get rid of.
i guess you'r still fighting it? :angelnot:
as far as relating to the problem, you can just pull the new wheel stud through the back, put the brake rotor on, put a lugnut on the new wheel stud. Tighten the @#$(& out of it. Pop the wheel nut off , pop the wheel on. Good as new!![]()
