NO Dashlights and i mostly drive at night
SHOlover1
virginia
ok i was driving down the road everything good. the come round a corner and look down noticed i had no dash lights, eatc button lights, ash tray. and clock back light all gone.
i have checked all the fuses under hood and drivers side found one blown but turned out to be the pw button lights.
i think maybe dimmer switch but it still turns on dome light so idk what is going on its a ***** to drive with out dash lights plz help plz help
chris richardson
jmpSHO
Massachusetts
Dude it's kind of late, I am sure you will get a few responses in the am. If all fuses are good I would have to guess that the dimmer switch was bad. Find one in a junk yard, probably for $5, and replace it.
sholover719
central va
off topic, but chris is lookes like we will be going to cap tomorrow and trying to find an sho down there.
walser
new ulm MN
i would say dimmer switch, but when mine went out it never messed with the EATC. it should only be the dash lights out. i would replace the dimmer switch, and there might be another reason why the heater lights went out. but if all fuses are good, go for a dimmer switch.
SHOlover1
virginia
sorry about the snap last night but it just put me in a panic...well got a update about the fuses in my 92 found two that had blow over night tryed to put new ones in there so i imaging theres a short in the dash some where so now im with out tail lights so now i cant drive in dark period idk if i wanta do search for it my self or not its the number 6 and 13 fuse how would i find the short?
SHOlover1
virginia
yea so in total i've lost dash lights, tail lights, eatc button lights, and ash tray. Any fuse i put in blows unless its thirty but then the dash smokes and thats not good with me i dont need a burnt down sho i could live with out the dash lights but i just got a speeding ticket and dont need one for tailights
PS brake lights and rear turn signals still work
jmpSHO
Massachusetts
I still think it might be dimmer switch related, alot of stuff runs through that. Like I said in my post yesterday, it's cheap at a junkyard so you might as well go get one.
SHOlover1
virginia
i have a 1992 mtx Taurus SHO taking it to the shop tonight to have fixed by the end of week hopefully before. i have 2 vehicles this and my 85 f150 which is almost a junker but it runs till i blow it up. so ill make do for a couple days with my truck i assume unless some one is around va and wants to help pull my dash apart
jmpSHO
Massachusetts
A dimmer switch isn't that hard to replace and doesn't require that the dash be removed. For the price a shop would charge I would drive out there and fix your car for you.
SHOlover1
virginia
well ill tell you i took it in for the diagnostics and it wasnt a dimmer switch it was the headlight switch all together... i was surprised
