Rattle - Exhaust? Ping?
SeanMc
NoMoSHO
[YOUTUBE]gR2CfSt2NIM[/YOUTUBE]
At around 2 seconds you'll hear it.
Seems to only happen at low RPM. Car hasn't lost any power, or so I can tell. 70k on the rebuilt motor.
geomarathoner
WV
Hard to tell....the squealing tires add to the difficulty.....but it might be that when the engine moves on the mounts at lower rpm, something in the exhaust piping is vibrating against the rest of the car. I had a similar sound which turned out to be the front exhaust manifold just barely touching the subframe at certain rpm/open throttle. FWIW
SeanMc
NoMoSHO
Thanks!
I'll check it out this weekend.
Vnuk1
Mr. Mayhem
I had a similar problem and it was the heat sheild on my cats. Just throwing that out there......
NEp8ntballer
cyber ninja
fifth circle of ****
I can't listen to the vid now but if you are still running cats they could be loose. does it sound like somebody shaking rocks in a can only more metallic? When the cat on my Jeep was on the way out it would only rattle at idle and would do it infrequently.
SeanMc
NoMoSHO
I have hollowed out cats...but it's a pretty old SHOShop ATX y-pipe. And yes, it sounds like someone shaking a coffee can with gravel in it.
Brian, I believe the flex pipe is good. Again, I'll look under the car tomorrow.
Ishodu
It could be that that baffle in the resonator is loose. Hop under there and bang things around see if you can make the noise with the car off.
SeanMc
NoMoSHO
Well, I finally was able to find what it was...it was the heat shield on the old hollowed out cats (I had new CARB cats installed yesterday). It's also in combination with leaky, and rattling exhaust flanges at the manifold, which I'll be getting fixed next week.
