Heater-Tube-Be-Gone
Get rid of the metal tubes completely - everywhere.
Buy the correct diameter heater hose for the entire length and/or the hose reducers for multiple diameter hose/tube runs - like when it leaves the engine block at 3/4" but enters the heater at 5/8".
Buy the metal coils made by Gates (?) ($6 to $7 each) that slip OVER the hoses (5/8" and 3/4" size) and then bend the coil with your hands to the correct angle to follow the same path as the hose/metal runs. They are made to VERY close tolerances to fit over the outer diameter so you will have to be careful when putting them around and locating them to the correct position on the hose before you start to bend them.
Clamp your hoses with ABA clamps - the best clamps made - that are SS; have solid, wide bands with rolled edges and and an enclosed worm gear assembly. They are worth every penny. (Twice the cost of IDEAL clamps, maybe). ABA makes clamps for the marine environment and they are used by the Navy. Go to ultimategarage.com for the cheapest prices.
Coat the metal male ******* and/or the inside of the heater hose with a very light wipe of a teflon based lubricant (I use ARP thread lubricant which has Teflon and anti-corrosive additives). Teflon decomposes at 500F so it retains its low friction properties.
No more metal tubes; no more tube corrosion; no more clamp corrosion; no damage to the exterior of the hose due to the non-solid band type clamps; and no more stuck hoses.
Nice looking runs of heater hose with coils at the appropriate places that bend the hose to trace the same path as the original runs.
