89 Transmission in a 94?
AREA 91
Area 91
Will a transmission from an 89 SHO fit in a 94?
If you have access to the donor car, take the rod shifter and innermediate exhaust pipe. The rod shifter is far superior to the cable shifter.
All 89-95 MTX tranny's are interchangeable.
TYSHO
Earth
As said they will switch. The syncro material is different though.
The synchronizers are the same, the blocking rings are what's different. The early models (89/90) had brass rings versus the later style, fiber lined rings. :thumb:
