91 Mocha Frost, Daily Driver
AREA 91
Area 91
3.2 swap with 3.0 cams
SS CAI
Stock MAF
Stock Intake
SS UDP's
Gasket Matched
Catless Y pipe
Dynomax Cat Back
TwEECer
On a Stock X2J program I pulled 210 and 210 at the front wheels.
What a great street package.
Ironically, when I (leaned out) the stablized fuel chart, I lost power.
Usually leaning out the top end results in more power. Not in my case.
Anyone venture to guess why???
Phoenix
SHOHOLIC
QC , Canada
Is this the one with pistons? (was it your father"s?)
For your question , could it be that you were already lean up front a bit , but when you leaned it even more it said NO? :sun:
Toolman
Boost it!
Grand Lake, Oklahoma, USA
SS CAI
Stock MAF
Stock Intake
SS UDP's
Gasket Matched
Catless Y pipe
Dynomax Cat Back
TwEECer
Well, you are already making a good deal more power than stock (close to 10% more HP and 20% more TQ), which suggests you are using a good deal more air than stock. What were the WB numbers?
Ishodu
Nice numbers, I find that I also make more power around 12.5 once I lean it out some I seem to loose as well. But I need to dyno test my own car soon as well.
AREA 91
Area 91
Nope. Junkyard 3.2 with stock pistons. Dad's 3.2 has stock pistons as well, just equiped with gapless rings.
This could be the case as it feels strong on the street.
Torque for the street! ;)
AREA 91
Area 91
No wide band was used, so I have no idea the actual A/F Ratio.
This is a junkyard 3.2 with new rings, bearings, and gaskets.
Tim,
My dad's 3.2 has Total Seal Gapless rings.
AREA 91
Area 91
Nope.
Good point.
Could it be that the computer think's it's still a 3.0???
If so, what do I need to change in the TwEECer so it know's it's a 3.2?
Injector size?
Displacement?
Phoenix
SHOHOLIC
QC , Canada
Good point.
Injector size?
Displacement?
Very good Q , but im at total loss with tuning/tweecer. Thats one thing im not interested in learning , specially when theres a SHONUT 2-3 hours away from home :evilgrin:
