boat
Likes blue ones
All 3 of my cam seals are leaking. Previous owner didn't replace them 14k miles ago when a 3.2 swap was done, but replaced everything else for the front 60k, gotta call him about the front main, also. I am looking at 3 options for the seals:
1. Buy from someone on here, unsure of brand
2. RockAuto BCN 1213N's
3. Ford Dealer, Genuine Ford OEM Seals
I have been reading this post to try to figure out which is best. Sounds to me like the BCN National's last longer than the Genuine Ford OEM Seals. Thoughts?
I have been reading and searching things out. To replace the rear cam seal at the cam sensor, I am going to do the electrical tape and grease method. But I am also going to remove the cam seal cap from the top (rear), after I take off the valve covers, gotta replace those gaskets, too.
My questions:
1. What type of RTV do I use to reseal the cam cap once I take it off and put it back on?
2. Do I need RTV for the seals if they are rubber coated, if so, what type, color, etc.?
3. What kind of grease should I use to help slide the cam seal in place?
4. Is it a good idea to do the electrical tape/grease method for the front 2 cams as well?
My questions:
