H.I.D. Upgrade- Lamp Out Warning Dummy Light??
FOMOCOTOSHO
I eat Rice.
Moorhead, MN
Hi everyone,
I purchased the new bi-xenon kits from the group buy listed here: http://www.shoforum.com/showthread.php?t=97641
Because of the way they are configured & installed, the kit only utilizes the one factory headlamp socket and the other is left blank, which of course the car doesn't like so I get that stupid "Lamp Out" warning light on the dash. A friend of mine thought he knew a way to trick the car into thinking it was fine but it didn't work.
Has anyone else ran into this on this or any other kits? And if so, can you tell me how to do it? It really drives me crazy seeing that damn light so bright on at night.
Any help would be appreciated! Thanks!
szillaxl
Ontario
I painted my lightbulbs black and left them hanging and I have the HID's in the headlight assembly I cut the connectors off and wired it off the battery with a switch and that solves the problem I thought the headlight bulbs would overheat and blowup when I painted them black but they didn't they still shine on under the paint.
Racer X
SHO Pilot, Retired
Connecticut
If it does, I've yet to notice any ill effects. Been unplugged since the LED tails for the Gen 2 were introduced on eBay; I bought the first pair.
jonheese
Used-To-Know-It-All
Fogelsville, PA
Hm. I think I may try this for my HID install, instead of cutting the two wires as in the jpg above. I like the reversibility of an unplug vs. a cut. Thanks.
Regards,
Jon Heese
jonheese
Used-To-Know-It-All
Fogelsville, PA
That link did not work, no image. Please help
Really? I just clicked it again and it showed just fine.
Let's try this instead:
Lampout
The basic gist of it is you cut the grey/yellow (G/Y) and brown/light blue (B/LB) wires coming out of the lamp-out module above the glove box and terminate them safely so they don't touch anything.
If I properly understand the way this works, I think that this disables the headlight functionality of the LOM, while still leaving monitoring of the other lights. Unplugging the module altogether would disable the entire lamp-out system.
Regards,
Jon Heese
FOMOCOTOSHO
I eat Rice.
Moorhead, MN
Lampout
Regards,
Jon Heese
Still no pic but I'll try your instructions. Thanks
