Storm-Chaser
I have the following items for sale (will be adding more over time). Prices do not include shipping unless stated. In those cases where I have a good idea of shipping costs, I have posted a "shipped" price. Most parts are Gen II, but I do have some Gen I and Gen III items. Payment via personal check or money order (preferred), I have made arrangements for Paypal through another forum member as I am currently out-of-state. References are available.
If anyone is looking for OEM/Motorcraft air conditioning lines I can get some/all of the A/C lines depending on model-year and application (ie. MTX -vs- ATX). I was able to get a five new OEM/Motorcraft A/C lines for my 95 MTX in 2007, which ran over $500 plus shipping. The OEM/Motorcraft A/C lines have become quite scarce, so let me know what you need and I'll see what I can find.
I also have access to OEM/NOS parts, including some discontinued and obsolete rare parts. Most are 10-to-20 percent below Dealer List (ie. dealer Parts counter price).
Engine / Transmission / Under hood:
Brakes / Steering / Suspension:
Interior / Trim / Miscellaneous:
Exterior / Trim / Headlights / Taillights:
NOS Items
Gen III Items
Items I have, but have to find (ie. let me know if I should dig for them):
non-SHO Items
Also have access to some Interior parts from Sables and Taurus for various years, let me know what you want and I'll check what I have access to.
I have considerably more parts I've collected over the years, which I will continue to add - so if there's something you need that's not listed, just ask.
- Duratec Coil-on-Plugs, set of 6 - $100 and shipping
(includes wiring harness leads for the Gen I/II Coil-on-Plug conversion)
- Motorcraft AGSP-32PP original double-platinum plugs, set of 6 - $55 and shipping
(I have several sets of 6)
- Lincoln Mark VIII 80mm MAF (OBD-I) - $80 shipped
(includes the Mark VIII airbox cover and OEM harness extension)
- X2J computer (from 92 MTX w/112K) - $65 and shipping
- D4U1 computer (from 95 ATX) - $65 and shipping [sold]
- MTX transmission - $275 and shipping
($350 delivered to Bizzy for inspection/rebuild)
- Rod Shifter - $100 and shipping
- 99 ATX Transmission Cooler and hardware (from 99 SHO) - $75 and shipping
(only year both cooler lines were finned, I'll have to check what other hardware/hoses I have, but it will be complete for shipping)
- 95 ATX Transmission Cooler and hardware (from 95 ATX) - $50 and shipping
(includes mounting frame-nuts, bolts, passenger-side line to radiator, driver-side line to T-fitting, and T-fitting)
- 94/95 MTX alternator (reman., like new condition, tested) - $75 and shipping [sold]
- 94/95 MTX/ATX alternator under-drive pulleys (OEM, new or used)
10% underdrive - $25 and shipping
(these are NEW OEM alternator pulleys)
7% underdrive - $15 and shipping [one pending]
(used alternator pulleys in good to excellent shape)
3% underdrive - $15 and shipping
(OEM > 3% underdrive > 7% underdrive > 10% underdrive)
- 92 MTX Alternator-A/C Tensioner - $60 and shipping
- 92 MTX Alternator-A/C Tensioner Pulley - $25 and shipping
- 95 ATX throttle cable (good condition, not frayed) - $30 and shipping
- 92 MTX throttle cable (good condition, not frayed) - $30 and shipping
- 95 Wiper Motor - $20 and shipping
- 92 starter (reman., good condition) - $45 and shipping
- 92 A/C Compressor (great condition) - $50 and shipping
- 92 MTX battery tray (complete, minor surface rust from battery spill) - $15 and shipping
- 24mm front stabilizer bar - $40 and shipping [sold]
- 22mm front stabilizer bar - $55 and shipping
- 20.6mm front stabilizer bar - $40 and shipping
- 23mm rear stabilizer bar - $40 and shipping [sold]
- Front Stabilizer Bar Brackets (new) - $35 and shipping
Front Stabilizer Bar Brackets (used) - $15 and shipping
(used with no to very minor surface rust, as available)
- Rear Stabilizer Bar Brackets (new) - $35 and shipping
Rear Stabilizer Bar Brackets (used) - $15 and shipping
- Aluminum Dual Piston PBR Calipers from a 2004 GT Mustang - $75 and shipping [sold]
- Aluminum Dual Piston PBR Calipers from a 2001 GT Mustang - $90 shipped
- Aluminum Dual Piston PBR Calipers from a 2000 GT Mustang - $90 shipped
- 94/95 Front Spindles (96 front brake upgrade) - $60 and shipping
(I can have the hubs pressed-off for cost if you plan to install new hubs, to reduce shipping costs)
($75 and shipping with both front ABS cables included)
- FN74 Caliper Brackets (96 front brake upgrade) - $45 and shipping [stolen by James, but I have more ]
(caliper bracket bolts are required if you’re upgrading from other than a 94-95 front brakes)
- 94/95 Front Caliper bolts (96 front brake upgrade) - $5 shipped
($2.00 if bought with FN74 caliper bracket - required if upgrading from other than a 94-95 front brakes)
(they’re now $13.50 each if bought new from the Dealership)
- 90-92 OEM rear brake upgrade kit (rear vented OEM brake upgrade) - $50 and shipping
(includes disc brake adapter plate and mounting hardware (ie. bolts) - dust shields $10 more)
($75 and shipping with both rear ABS cables included / $80 with ABS and dust shields)
- 90-92 Rear Calipers (reman. loaded) - $130 and shipping [sold]
(complete and still in plastic-wrap - remanufactured by Morse company)
- 90-92 Rear Calipers (used) - $100 shipped
(complete with good piston boots and slider pins)
- 94-95 ABS Control unit (HCU) - $65 and shipping
(complete unit)
- 94-95 ABS Bundle Assembly (from 95 ATX, 119k) - $25 and shipping
(minor surface rust on lines from master cylinder, and to left-front brake line)
- 90-92 ABS Bundle Assembly (from 91 Plus) - $30 and shipping
(minor surface rust on line to right-front at the distribution block, will be treated/removed before shipping)
- ABS Cables - $15 and shipping
Both fronts - $25 shipped
Both rears - $30 shipped
entire set - $50 shipped
- brake lines - price dependent upon line, year, and condition (several complete and partial sets available)
- GTP rear control arms w/o shim kit - $ price dependent on condition (I have two complete sets; one pending)
set of (4), unmodified - $50 plus shipping
set of (4), modified - $75 plus shipping
set of (4), modified with reducing sleeve kit - $115 plus shipping
- ABS harness retaining clips for GTP rear control arms - $10 for left/right ABS harness-leads / $5 with GTP control arm set
- Gen III Subframe Bushings (used, set of 4) - $50 and shipping [two sets sold / third set available]
(Subframe Bolts $2.50 per set if bought with Gen III Subframe Bushings - with no to very minor surface rust, as available)
- EATC, Hardbutton, green display (dealer warranty service replacement) - $85 and shipping
The top EATC unit is the dealer warranty service replacement, and is slightly smaller than the replacement unit on the bottom.
- EATC, Hardbutton - $60 and shipping
- Door Panel set, Mocha, Gen I - $100 and shipping
(excellent condition)
- Console Bracket Set for Gen I > Gen II console conversion - $30 and shipping
(includes all four brackets and hardware required to install the 93-95 console in 89-92 SHOs)
- weather stripping seals - no tears
driver’s door - $30 shipped
other doors - $20 shipped
front doors - $45 shipped
entire set - $75 shipped
rear trunk - $30 shipped
- Gen II Digital Instrument Cluster and Bezel (from 92 Sable) - $ best offer
- Gen I Digital Instrument Cluster and Bezel - $ best offer
- Blend Door Actuator - $40 and shipping
- Blower Motor Control - $25 and shipping
(used, pulled from Continentals, Sables, and Taurus)
- Gen I Plus Spoiler (91 Plus) - $125 and shipping [pending]
(in very good shape; all brackets intact; complete welt seal; surface damage to paint on passenger side)
- Gen I Plus Taillight set (both, amber inset, 91 Plus) - $65 and shipping
(both lens in excellent shape; right lens has minor crack from trunklid)
- Gen I Plus Taillight (right, amber inset, 91 Plus) - $30 and shipping
(lens in very good shape; one bulb socket partially melted)
- Gen II Spoiler LED Third Brake Light - $30 and shipping
(no broken mounting tabs; will get picts when I can)
- Gen II Spoiler LED Third Brake Light - $20 and shipping
(one mounting tab broken, I have that piece so it can be JB welded back-on)
- Gen II Header Panel - $85 and shipping
NOS Items
- driver’s door weather seal - $95 plus shipping
(Dealer List is $115.42)
- Gen I Back-glass bottom weather strip - $40 and shipping
(used also available, $20 and shipping)
- OEM Knock Sensor (Ford blue-box) - $35 and shipping
(1 available, one of the three small tabs is partially broken-off)
Gen III Items
97 cam-welded Engine:
I have a Gen III cam-welded engine that is from a wrecked 97 SHO. The SHO had 180k on the odometer, and both valve covers were pulled to verify the position of the buckets. I have not heard the engine run, but at worst this is a complete engine with welded cams. I am looking for the best offer above $750 and will consider delivering within a reasonable distance of St. Louis for an additional fee. Email me for information and/or the vehicle VIN. This is a possibility to get a cam-welded engine for roughly the cost of a cam-weld, and 1/2 the $1500 price of a complete cam-welded engine.
- 99 Transmission Cooler and hardware (from 99 SHO) - $50 and shipping
(includes mounting frame-nuts and bolts, I'll have to check on what other hardware I have for it)
- 99 ABS Control Module and pump assembly (from 99 SHO) - $125 and shipping
(items list separately new from Ford at $1,493.70 and $776.35 respectively)
- 99 ABS Bundle Assembly - $25 and shipping
- 97 ABS Control Module and pump assembly (from 97 SHO) - $125 and shipping
(items list separately new from Ford at $1,462.58 and $776.35 respectively)
- 97 ABS Bundle Assembly - $30 and shipping
(brake lines also available, I'll update which lines are still good later)
- 97 ZF steering rack (from 97 SHO w/182K) - $100 and shipping
- YLY1 computer (Ford reman., from 97 SHO) - $100 and shipping
- Front License Plate bracket (Black, from 97 SHO) - $30 and shipping
- Accessories Belt Tensioner (from 95 ATX) - $65 and shipping
non-SHO Items
