Cruise Control not working???
Irish Pride
Irish Inside
MusicCityUSA
The cruise control on my 91 does not work. What causes this to happen? What do i need to do to fix it?
Could be electrical - bad connector, bad servo, bad vss, etc.
Could be vacuum problem - vacuum leak, bad hose, hose off, etc.
You will need to do some investigating to see what you see that doesn't look right.
encryptshun
Florida
dude mine whole thing isnt even in there, the person who had it before me ripped it out, and no my horn doesnt work either, do you commute alot of something, i never drive far enough to even think about it
jonmon6691
No dough SHO
Wilsonville, Oregon
that sucks, my cruise control being operational is the only thing that has kept me from getting a ticket.
Me too, I can't drive 55 :D
@ the OP, there is a clip that hooks onto the throttle body that tends to come unclipped. Check that before you do any drastic electrical diagnostics or replacements.
Irish Pride
Irish Inside
MusicCityUSA
Does the horn work?
i dont know. i'll check it out tomorrow. what does it mean if the horn doesnt work?
i'll check that out tomorrow too.
projectSHO89
SHOless In St L
St. Louis, MO
There is a stickied post in the "How do I..." forum that gives info on the 89's CC system. As noted in that post, it should also apply to the 91.
Refer to it, then post back in THIS thread (do not post in that stickied thread).
tardboy21
Woodbridge, NJ
When I got my 92, the cruise didn't work. The clip attaching the cable to the throttle body broke. A couple zip ties and it was an easy fix. good-luck. :thumb:
Devin
3.Slow
Pacific Northwest
I had the problem where my horn and cruise control didn't work. Turns out it was the clock spring. I replaced it and everything worked like a charm.
