Tranny randomly up and downshifting
SeanMc
NoMoSHO
Driving home from work today, I get on the freeway and hammer it. It shifts like it's supposed to, but then it all the sudden downshifts and hits redline. I let off the gas, and it holds at redline for a few seconds, and then slams back into 2nd. Cruising another mile to my exit, it seemed fine. I got off the freeway, and it gear hunted again as I was bringing it to a stop. Made my turn and then it wouldn't shift out of first until I let my foot off the gas. I came to a signal light, and it died. Started right back up, and seemed ok, until I came to a stop where it idled 3-400rpm higher than usual. I babied it home where it seemed ok. What's going on? TPS? VSS? Oh, codes show 511 (LPM) on KOEO, and 111 on KOER.
SHO Continental
Moderator
Northridge, Cali
That 'ATX' is your problem. :p
Symptoms sound similar to the original atx in my '93 about 2 weeks before it 'sploded.
Don't try to use this as en excuse to get out of the track day next month either!
SeanMc
NoMoSHO
Well, I went out to check on things, checked codes and came up with a 335 (EGR out of range..yeah, ok). While the motor was running, I heard a knocking coming from the coil pack area. I took off a wire and saw a blue-ish powder like coating on the contacts...4 of them in fact. So I got some steel wool, and cleaned them off. Put the ends back on the CP, and fired her up, idles like silk, ok, cammed silk now. Went for a 10 mile drive (um, sprint), and everything was back in order. Will let you know if it happens again.
hawkeye18
Sorta cares
Norfolk, VA
Huh. I fail to see how a spark malfunction could cause a transmission to randomly shift, but I guess I can't say I haven't seen stranger things :shrug:... so I guess congrats on finding the problem! lol
CademiaX
What's an SHO?
Utah
Hmm, I would keep an eye on it, if that was the problem I'm sure it would have miss fired and threw some mis-fire codes.
SeanMc
NoMoSHO
Ok, just went on a 45 minute cruise. Lots of upshifting, downshifting, stops and goes. No problems. I guess it was shifting like it was supposed to, but the revs were off. Anyway, since all is good now, I'm sitting here enjoying a big slurpee (it's 75* outside).
CademiaX
What's an SHO?
Utah
Well, lets celebrate, just bring me one of those slurpees :)
TopGunnYFZ
Livonia, MI
My car shifted crazy one day too, I was bracing myself for an explosion but I made it home. Got in it the next day and it was fine and has been since, that was about 6 months ago? Maybe it was having a bad day
hawkeye18
Sorta cares
Norfolk, VA
This is true, I had a weird day a long time ago with mine... it was real hot outside and the tranny was acting really sluggish and didn't want to stay in gear... then I got a DTC for "incorrect ratio for 3rd gear"... wtf? But it hasn't done anything weird since then.
Mr Anonymous
Tire Wall
St. Louis, MO
Does your cruise control work? If not, that's usually the sign of a failing VSS.
How is your fluid level/condition?
SeanMc
NoMoSHO
Fluid level is perfect. Had it flushed about a month ago, and it's nice and pink. Cruise works. Everything is fine.
shobroooo
