Team Dave
SHO n00b
Hopefully I can get some insight here, as I am a little confused. All I wanted to do was see if my 3rd brake light was still working, and I found out that none of them were! :woo-hoo:
I've done some research, and messed with a few things but haven't fixed it yet. All the searching I did couldn't help me either (you'd be surprised at the amount of "ATX/BOO Can't get out of park" threads there are!).
Here's my dilema. I'll try to cover anything I've done that may be related to it. I bought the car with a non-working 3rd brake light. I figured the LED's were dead, so I bought a new one on eBay, and it worked great. When I first bought the car, it's BOO was a bit melted towards the front (closer to the driver), but I solved this issue by taking off the top portion, and directly plugging the wires into the BOO (with those pancake lookin connectors. I have no idea what they are called). I checked to make sure it was all working right, and everything seemed fine.
Now, all of a sudden, I don't have any brake lights. I checked out the BOO, and all connections are solid, and it is getting constant power like it should. There was a black plastic piece poking out above the BOO that I had to re-insert into a white clip that pivots on the brake pedal, but I don't think this is related (I'm assuming it has something to do with cruise control?).
I've also checked the fuse (#1), and that was fine too... BUT there was a 20 amp there when it should be a 15 amp. I swapped it back to a 15, but I don't think that is what the problem is. It may have contributed to the partially melted BOO, but I don't see it negatively affecting anything else since it wasn't much larger of a fuse. And FWIW, my melted BOO is only cosmetic at this point. From what I can tell, the BOO is working completely fine. I'll probably replace it anyway, but I think my issue lies elsewhere.
That's it for the most part. I don't think theres any faulty wiring in the car, so I'm really trying to avoid having to trace it all to the fuse box. Anyone have any input on this?
