differnent LED tail lights
SHOSource? Which is it? is the flasher included or is it an option? Quoted from shosource.com...
The Grote electric flasher module can be included as an option included to reduce confusion and make the lights a true drop-in replacement.
We also offer the Black Out LED lights as well to truly set your SHO apart!
Tech Notes
Includes the grote flasher needed so that they will flash correctly.
LOUDSHO92
Rancho Cucamonga, CA
Its an option hence why we have the option at the bottom. I have updated so it isnt confusing.
Devon
Fort wayne IN
I still don't understand the Grote electric flasher module ?
what is it and why would I want it?
SinisterSHO
Rust free
630, IL
the LEDs will have less resistance than a regular bulb, so the flasher module will make them blink like they normally would, or at least that was my understanding.
92sho16
b00sted
Liverpool, NY
An old style flasher is like a circuit breaker, two different metals make up the contact and when x number mA flow through and heat up the contacts one of them peels away. So changing the lights in any way that increase the current will decrease the amount of time it takes to flash. The electronic flashers are not load based and have fixed timer circuit therefore no matter the load the same flash rate results.
