How do you get the front Ecable off the car?
strykr14
Michigan
I found a brand new E cable on a car in the boneyard for my 92. I disconnected it at the pedel and pulled it through the floor. Disconnected it at the caliper as well. The cable goes through 2 brackets on the floor/
This is the 1st bracket. It is just behind the front tire. the bigger part of the cable is toward the front of the car, so the cable pulls out th front after it is piched smaller to go through the bracket BUT, below is the rear bracket (looking toward the rear) and from what I can see, it would pull out at the rear of the car. So what do I do here - it can only come out one way?
strykr14
Michigan
you have to squeeze all the metal fingers in toward its body to pull it out.
I see that but the problem is that you there are 2 brackets, once the metal fingers are squeezed on both the come out but on opposite ends. One comes out toward the front of the car, the other toward the back. If they both came out the back for example, there would be no problem.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
its been a while since I looked at the cables closely, I seem to recall a sleeve connector between the brackets about under the drivers seat. get a couple of screwdrivers and pliers to open that coupling. something about moving a tab then sliding the slug to the center of the coupling to free it. or is the trick to adjust the cable for slack then just pull the slug to the center and release it? try seperating the cable at the parking brake pedal to release the tension. oh yeah, I always end up swearing at cable issues, that always seems to help
strykr14
Michigan
Well, I have already sworn at it a lot and it hasn't helped. I will try your suggestion though!
pjtoledo
'ol man in the SHO
toledo,ohio,usa
AH HAH I remember now. I had some pliers that I could snag the slugs with and was able to slide one of them to the center and pop it out. sorry it took the 'ol brain so long to recall those data bits, but hey, I'mm over 55 and ,,and,,, what were we talking 'bout?
strykr14
Michigan
Don't worry about it - I have learned alot more from guys over 50 then I ever have from guys in their 20's!
So doing that, the Ebrake cable can be put back together again?
shoon
cliTaurus
Dawson Creek, BC
on my 95 there are 3 separate ebrake cables... 92 should be the same
one for the left rear, one for the right rear, and then the cable the links the 2 rear cables to the ebrake pedal.
If you are replacing the cable that clips into the ebrake pedal, you shouldn't have to disconnect any cables from the calipers (unless your doing 2 or 3).
As mentioned just pop the fingers and they will slide out... mine were badly corroded so I opted to hack and slash everything out before installing new cables.
OH also there should be a coupling type thing that connects the lead cable ends together... they are easy to snap together with vice grips but taking them apart without destroying them is sometimes tricky.
strykr14
Michigan
That's what was throwing me for a loop - it's the couplling thing I'm having an issue with. Any tips on "uncoupling" it
shoon
cliTaurus
Dawson Creek, BC
one pair of vice grips, and one pair of needle nose pliers worked for me. If its a bit rust its going to be hard to remove it without destroying it... the cable should have come with a new piece, unless someone stole it out of the box?
grab the base of the cable with the vice grips and try and snap the piece out as if you were breaking a twig in half; its tricky.
strykr14
Michigan
Well I got it. If anyone else is ever wondering, I put a picture of how the cables are connected. The picture shows the tab that needs to be lifted with a screw driver - you can see where I scratched it a bit. There was no rust and after the tab was lifted I pushed the cable toward the other one (Teh one where I did not lift thet tab) and they came apart with ease. Thanks for all your help.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Thanks for the picture!
One of the items Ive got on the "to-do" list for the old '89 is ebrake cables.
This helps! :thankyou:
raff18
frosty95mtx
ontario canada
i used a pair of needle nose vise grips and opened then way up and jut closed em up the a little more and a little more and a little more ........ u get the point and pop it went from there it was a cake walk
pjtoledo
'ol man in the SHO
toledo,ohio,usa
a pic of the other side is in order here, that will explain it better
tinkerkathleen
