84K miles, should I do the clutch
strykr14
Michigan
Car runs fine but I am switching out the subframe, halfshafts, and doing the oilpan gasket. I have extensive records, the clutch has not been changed. Should I do it now, I found this in Ebay:
Kit # 07-082N
89-90 Taurus SHO 3.0L
9-1/4" 235 MM Clutch
9-1/4" x 7/8" x 20 Spline
$105 is the buy it now - this'll fit my 92?
dis8tat
denver
not sure if the clutch will fit. but if you are pulling the subframe do the clutch it should only take you another 25 - 30 mins to pull the trans, clutch and flywheel. to me i would just do it now it only make sense. good luck
1993MTXSHO
Its a Taurus...
Jersey
That is not the right clutch for a 92, that's the old crappy clutch that got recalled from 89's and I think early 90's. You will burn it up in no time if you beat on the car at all. You want the updated 9 3/4" clutch it's much MUCH better.
dis8tat
denver
I guess I would be taking a chance on wether or not it would fit
i would agree because 89-91 is gen1 and 92-95 is gen2. so therefore i would say no. but at the same time i am not sure if gen1 parts cross with gen2. if i were you i would just spend the extra cash on the clutch of your choice for the gen2. if you are not heavily modded just buy an oem replacement. i just put a LUK clutch set in mine so far so good but it has only been about 10k, and i beat the shit out of mine so we will see.
Kens1992mtxSHO
The Commonwealth
85k on the original clutch is awesome, but that doesn't mean it's going to go anytime soon. If you're **** bent on replacing it get yourself a LUK or OEM clutch. You just don't need more than that unless you're heavily modded.
yep, that's a Tempo clutch. 9 1/4".
You want the 9 3/4" ... because of your flywheel...that 9 1/4" version has plenty of bite for a stock car, it just wears out slightly faster.
strykr14
Michigan
OK, thanks for the input guys. I'll double check my records but I think that it is the original clutch.
shobote
Naperville, IL
Have heard rumors about a lot of failures on the small clutch while the original 9 1/4 clutch in my '89 lasted 140k, I bought it in 1990 with 20k on it and the TOB finally gave out, but the clutch was still grabbing. I think the TOB was more of a problem than the clutch; One of the reasons the '89 was the fastest stock SHO was the lighter clutch.
Go figure, the OEM Ford replacement clutch and new flywheel with 9 3/4 was already slipping after only 10k mi.. The pressure plate is much heavier on the larger clutch. WIsh there was a lighterweight version out there.
