wymjym
I had my tranny rebuilt last year, it was not a good experience.
At any rate, I am certain that they installed the incorrect tcc solenoid (wrong ohm readings). I also have some very very hard shifts going from 2nd to third...most of the time. I have the car ripped apart and will be pulling the side cover off tomorrow. My question is, since I can replace the solenoids without yanking the valve body off I am inclined to just order the solenoid pack (five new pieces) and install them...button it back together. That is unless I might be able to actually see if any of the valve body parts are damaged by pulling it out. I don't really know what I would find and unless there would be some obvious gouging or broken piece I wouldn't know where to look or what to look for. So....if I pull the valve body will it be of any use to me? or should I do the solenoids and cross my fingers real tight?
thanks for any insight
wj
wj
