twr
whoohoo
Here's a really good technical explaination from Gary from another forum regarding this subject.
(Zeptoplix @ Apr 16 2005, 11:35 AM)
Not really. The maf measures air in a vaccuum. not compressed air.. compressed air is more dense, well obviously... I dont see how it could get an accurate air measurement since its not designed for compressed air. The computer will compensate for the air you pull through the maf. not sre about pushing it through tho.
(gmorrell @ Apr 16 2005, 8:46pm)
No, MAF's measure mass flow; grams/second, kilograms/hour, pick your favorite unit, but its mass flow, and its independent of pressure and temperature. Mass flow is the same on the intake and discharge sides of a turbo or supercharger compressor. If it isn't, then there's a leak, or you've figured out how to violate several well-established Natural Laws.
For a hot-wire MAF meter, basically: I^2 = A + B sqrt(Ga)
sqrt = square root
Where I is the hot wire heating current,
A and B are constants relating to physical properties of air and the MAF design,
Ga is the mass flow rate.
please explain...
