Since everyone else is doing it, I figured I'd post mine too
As some of you already know, I made the decision last November to supercharge my car. Since then I've been purchasing parts and installing them. I wanted to have the car going by March, but I was held up on parts... Even now I am held up on some parts that should be here tomorrow. I start putting the blower stuff together and find out yet another part a certain SHO vender has forgotten...
My plan is to finally start the car this weekend. Once I get the last fittings in for my AMSOIL kit, I can adapt it to my Accusump and start the car. Since I've upgraded to the blower, I've since upgraded many parts and have basically pieced the whole thing together myself with the exception of buying the piping and bracket from SHO Shop. I've yet again upgraded the brakes to SHO Parts NW 13" front brakes and SHO Nuts 11.6" rear brakes. To accommodate the large brakes, I've added 17" wheels an lowered the car.
I'll start and tune with 9lbs of boost and then upgrade to my Reichard Racing 12lbs pulley. I'll be using a Coolingmist 2-stage water injection kit for charge cooling and a TwEECer RT to tune (of course!
) To monitor the motor, I've added a few more gauges, swapped from electrical to mechanical, and have added a knock monitor.
I moved the idler pulley for maximum belt wrap. I honestly don't think you can get more than this.
The only thing I have not figured out is how I am going to make the bend from the BOV to vent it back into the intake just before the blower since I am running the MAF pre-blower. Here is what I am looking to do... Any suggestions are welcome.
I did run into a bit of a problem... Last year I installed stage 1 cams and since then, I've had an oil leak I could not fix... It was leaking near the cam sensor, so I replaced the seal and the valve cover seal. After that did not work, I finally (last week) pulled it apart, yet again, and examined the camshaft. I found that whoever SHO Shop had grind the cams, removed the camshaft plugs and did not replace them. Oil was entering the hollow camshaft from the timing chain side and flowed through the camshaft out of the motor. I went to a local machine shop and picked up three 20mm plugs and installed them with the cams in the car. It was a pain, but they are in and that *should* get rid of my oil leak.
