Y-Pipe for 95 SHO ATX-What's available?
The_Vigilante
Texas
It appears the options are limited for buying a Y-Pipe for a 95 ATX. I found a CATCO on ShoSource-is it a quality piece? Are there any other companies making Y-pipes for an ATX? Thanks in advance
Frank
El Paso, Texas
90 SHO RIP
95 SHO
The_Vigilante
Texas
Thanks for your suggestions. Is it true that the ATX Y-pipe doesn't have as much restriction as the MTX Y-pipe? Any HP gains to be made replacing the stock Y-Pipe? Thanks
SHOtimer
#2910
Santa Clarita, Ca
Correct. The ATX Y-pipe is not a bad design....you may gain some but not a ton from a new one. The MTX Y-pipe has a 90 degree bend it in going into one of the cats. Horrible design.
Doug
ribeye2065
