I have a used front mount that is reinforced with a larger, welded limit bolt, and urethane filled. It's a stiff mount, and I took it off my '92 MTX because I prefer the feel of a cushier stock mount. If you want it, how about $20 plus whatever a USPS flat rate box costs? PM if interested. If you go with this, you must upgrade the two motor mount bolts to 10x1.5x100mm grade 10.9 ****** bolts; available from boltdepot.com. Don't reuse the old ones!
If budget allows, the front motor mount that Josh at shonutperformance sells are brand new mounts that have a properly reinforced limiting rod added. I think those are the best available, not cheap, but you definitely get what you pay for. You can buy through shosource.com or direct.
Rear mounts are still available from the aftermarket at reasonable prices, afaik.
