shoon
cliTaurus
So was throwing everything back together and I used some RTV on the o-ring between the waterpump and engine block. I wasn't sure about it, so I did some research and found its usually not advised because the o ring needs to "float", but sometimes is acceptable depending on application.
Has anyone used RTV on the o ring before and does it work? or should I rip it apart clean the surfaces and fix it?
