smokinshogun
So Im gonna make this lexury sedan more of a lightweight (hopefully) car. So after taking obvious items out. Hood pad, engine trim, interior trim, front fenderwell shields, headliner and roof gutted (moonroof). Also trunk liner, carpeting, gonna work on the sound material below MAAYBe, and gonna get a carbon fiber hood. Get rid off stock stereo amps subs and wiring. And replace with easliy detachable upgraded subs and amp. Console's gone and head unit might be moved to the climate control spot. Rip out the AC completely, and all wiring related to it. Crueise control will be gone, battery in the trunk.
This is all because its a 3.2 with 75, 000 miles. Although its ATX, I think it might be worth it while converting it to MTX to just make an adapter plate right? Then get an easily available manual transmission and then finally TURBO.
So looking at seat options so I took out the passenger side one and thats a heavy seat. But the mounting of it is also very weird to the floorpan. So looked higher up and the actual seat mounts to a bracket. I have yet to measure but it looks like theres a way I could use the old brackets gutted off power. Would this work you think? I could even leave the power to go front and back to mount the seat and once I like where its at then strip the motors. Ill measure soon but on jegs it shows all the mounting the seats below the seat. So even if the holes dont line up close make a couple 1/4 plates to make up the difference. I hope.
Tell me what you think or what people have done before. I just want light cheap seats not that compfy or anything.
