working the bugs out
JaxPT
Atlantic Beach, Fl.
Ok so heres what I have so far, I fired the car up and I have a serious idle surge issue goin on, it jumps from a near stall up to about 3000 rpms then drops back to an idle around 1000 rpm and almost like clockwork.
I attempted to remove the IAB sensor, managed to get the top bolt off but I cant seem to get a grip on the lower bolt, I rotated the IAb unit toward teh firewall as far as I could but I still cant get hold of the bolt to break it loose without the allen wrench slipping. any tricks to getting this thing off?
I removed the intake and cleaned the TB as best i could with carb cleaner, reconnected everything and it held about 1000 rpm idle for maybe 5 mins before it started the surge again.
after getting thoroughly PO'd I gave up on the engine for awhile and started messing with the moonroof, when i hit the switch I could hear the relay behind the glove box clicking, I pulled the wires from the relay and tried just reinstalling them but still no go the motor wont kick on. bad relay or bad motor?
JaxPT
Atlantic Beach, Fl.
good question, I just got the car last night and started working on it today. I need to find the connectors in the harness to clip and check the codes. I dont have a manual on this car and dont know much about em just yet.
forgot to add in order to get it started I need to pump the pedal a few times if that helps
JaxPT
Atlantic Beach, Fl.
just ran the codes, maybe I didnt read it right though.KOEO... CEL flashed once then paused and ran codes :
15 (O) No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
19 (O) No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low
96 (O) Fuel pump monitor circuit shows no power
I think i'll retry it again because it doesnt seem right for some reason
