munkee
Too busy...
This is annoying. I have a 91 plus that I fixed up and drove home from MT to SD last fall. I didnt have any problems with it. The car was parked for four months while I went to basic and ait. My buddy was going to bring it to the airport for me but when he went to start it, the negative battery terminal melted off. He bought a new battery and starter relay, but all it would do then is click when he turned the key. I had a good starter in the garage so we changed out the starter. That didn't change anything so we inspected all of the wiring and fuses, replaced the IRCM and ECM, and still no change. When you turn the key to on, the pump primes and everything clicks like it's supposed to, and the tach needle goes up a little bit. Then when you turn the key to start, the starter relay buzzes, and the tach goes up to 3 or 4k, but it doesn't turn over. I'm working on pulling the codes. It's been a while so I had to look up how to do it again. Any ideas?
