1994MTX
Recent Work:
-3 weeks ago, muffler blew, so i cut both off where they were welded
-car started missing occasionally 3-4 days ago
-found the belts were both worn literally in half
-swapped belts yesterday and started it up, i got misfires/backfires all the way home
-got home, shut off ignition, sat for 15 minutes, checked under the hood and found the one-wire clip on top of the alternater was almost disconnected (plastic clip holding in place is cracked)
-I reconnected clip and started engine, it idled fine, ran strong for about 3 miles then started missing again. Checked alt. everything connected.
-got home and it was idling between 500-800 rpm when it wasn't stalling, disconnected idle control and engine stalled followed by release of pressure (fuel?)
-when i gave throttle it would miss and backfire like crazy and not go any higher than 2500-3000 rpm
-today it'll turn over but no start
-never had CE light
-never had CE light
