windsheild washer
wingtip80
delaware
The pump for my windsheild washer stopped working? How do I access the motor? Do I have toe remove the entire fender?
Removal and Installation
1. Remove two retaining screws.
2. Remove RH inner splash shield.
3. Disconnect electrical connectors.
4. Disconnect hose and remove reservoir from vehicle.
NOTE:
Reservoir will drain with hose disconnected.
5. To install, reverse Removal procedure. Fill reservoir with fluid.
Make sure it isn't the switch first.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Push the plunger for the washer, hold it in and wiggle it.
If the wipers run, but the washer doesn't, then it's the washer.
Don't forget that there needs to be fluid in the tank (duh) and there's also an inline filter that can get clogged. This filter is inline and right around the strut tower area. Looks like a little white hose connector.
