Windows and locks stopped
wojo1989
Well I have had some problems with my windows. Passenger window has major window electrical problems and the passenger rear only goes down when the drivers door is open part of the way.
All that aside, in a short 10 min trip home from work the locks and windows all quit working. The problem is that my drivers window was down half way and its raining now :laugh_ti:
Any ideas? I hate electronics.
jesshasasho
SHOgirl
Canton, Ohio
Does the seat have something to do with the rear power windows not working? Neither of mine will work at all, and the seat only sometimes moves. Most of the time it will just **** a tiny bit in the direction of the button you pushed.
93rev2sev
Hockeytown
I dunno, I lost my door locks and seat motors...all my fuses are fine. I have to check the underhood power dist box now...
Might be the wire loom going from the drivers door to the body if they work when the door is partially open.
frosho
WOLFMAN
Tyngsboro, MA
my front passenger side window only opens with the driver's door fully open, using the switch on either the driver or passenger door, but when i want to put it up, i can do it with the door closed using the passenger door. i assume that points to the driver's door wiring. also, my door locks on both driver and passenger doors only work occasionally, and sometimes only lock or unlock will work. i'll hopefully be picking up the wiring for the driver's door from a JY this week, so i'll let you know if it fixes anything. that wiring is the same for both SHO's and SLO's right?
JustinSane
SHO OFF
PA SHO Shop
if the problem is verified to be related to the drivers door being open at a certain point then the problem almost has to be the harness going into the door, a wire has bent and snapped and only touched at a certain spot now.
