Will it work? 94 Lincoln Cont. EATC in a '92 SHO
92DOHCSHO
Shelton, WA
As the question is, will it work? I found a hard button EATC in a '94 Lincoln Continential. I was wondering if it would be a direct fit in my '92 SHO.
only1me
Missouri
Yea it will work up till 94 will, 95 was differant though, their is just a pin you will have to clip of to line it up with the dash to mount but thats it. I know cause I asked before also, and jelloslug told me the same thing.
92DOHCSHO
Shelton, WA
Thats good information to know. The boneyard down south told me that the only eatc that would fit my '92 was from '92 - '93. Thanks for the info.. :)
only1me
Missouri
yepp the taurus/sable to 95 works and the continental to 94 works.I recently replaced mine but I got lucky I got a eatc out of a 93 taurus that was a hard button replacement.
92DOHCSHO
Shelton, WA
well, i got it replaced. but for some stupid reason the outside temp reads at -40. any ideas on how i can fix it?
only1me
Missouri
Thats weird ,does all the other functions work fine? They should, did the one you replaced have this problem?
jelloslug
Digital
Greenville, SC
That sounds like the outside temps sensor is unplugged or the coolant temp sensor is unplugged. The outside temp sensor is on the radiator panel near the upper airbag crash sensor and the coolant temp sensor is in the hard pipe that goes to the heater core. Don't confuse it with the temp sensor that's near the thermostat for the gage or the temp sensor that's on the rear head that's for the ECU. I would also check for bent or corroded pins on the EATC unit and connectors.
92DOHCSHO
Shelton, WA
I dont think its the sensor. The outside temp thing worked on the unit that was originally in it. But when I the the remove/replace for the one I got at the boneyard, it didnt work.
